TwinTurbo.NET: Nissan 300ZX forum - Re: strange that both are lined up except crank pulley
Cjw3
on March 16, 2013 at 6:50 PM
strange that both are lined up except crank pulley (n/m)
posted by evan_aggie
on March 16, 2013 at 05:44 PM
Then the Belt wrinkle went under the crank.. are all the cams still lined up to each other?
Cj
Timing Marks & Debug
evan_aggie
12:45:39 03/16/13
Always
Cjw3
15:33:43 03/16/13
evan_aggie
17:44:03 03/16/13
Re: strange that both are lined up except crank pulley -
Cjw3
18:50:10 03/16/13
I'm about to pull the water pipes. I think I'm going smoked
evan_aggie
19:17:30 03/16/13
Not belt stress..
Cjw3
19:59:46 03/16/13
Holy F. No clue what happened. BTW: Greddy Belt or OEM?
evan_aggie
16:45:34 03/17/13
I'm an OEM guy
Cjw3
22:28:55 03/17/13
That gap looked like 4mm to me, *shrug*. I'll go OEM. (n/m)
evan_aggie
23:51:04 03/17/13
Replace the adjuster!
Cjw3
06:41:03 03/18/13
"Shock Absorber"? Isn't that just a heavy duty coil spring?
evan_aggie
08:13:28 03/18/13
Shock Absorber.. or something
Cjw3
13:34:52 03/18/13
BTW: Coz says that crank pulley mark won't line up.
evan_aggie
15:30:22 03/18/13
Actually, I think I disagree with Coz, but again, will check (n/m)
evan_aggie
16:09:14 03/18/13
The pulley or the gear mark? (n/m)
Woody75 (Denver)
19:58:03 03/18/13
The pulley TDC, not the gear. I thought back timing cover
evan_aggie
08:07:37 03/19/13
All Marks are timed at TDC #1
Cjw3
09:04:30 03/19/13
evan_aggie
10:15:17 03/19/13
The gear dots should match backing plate, belt lines wont (n/m)
ttsmokin
23:14:05 03/18/13
I used an OEM tining belt during my rebuild
SammybTT(TN)
13:49:23 03/18/13
FYI.. the backing plates are ajustable and can move..
Medallion Man
05:16:30 03/20/13
