TwinTurbo.NET: Nissan 300ZX forum - It doesn't work like that
Subject It doesn't work like that
Posted by ttsmokin on March 14, 2013 at 9:09 PM
  This message has been viewed 342 times.
In Reply To Spark plug gap posted by GotTwins90 on March 14, 2013 at 06:36 PM
Message You will not notice the difference between 0.035 and 0.040 at idle, you should not anyways. Decreasing the plug gap is to cure a misfire/stumbling at high rpm caused by spark blow out when the boost is raised.
You probably have another issue, unless you messed up the plugs while gapping them. You can't go at this wildly, you need to be careful about the delicate electrode. You can ruin a platinum/iridium plug by touching the tip with an instrument. You never pry against it.
Do the 6P's first, then inspect plugs for damage.
