TwinTurbo.NET: Nissan 300ZX forum - Replaced Knock sensor, still code 34
Subject Replaced Knock sensor, still code 34
Posted by BlackholeZ on March 11, 2013 at 5:23 PM
  This message has been viewed 184 times.
Message While I had the engine out replacing my turbos, I took the opportunity to replace the knock sensor as well. Of course the connector was wasted, so I crimped on a mini female spade, stuck it on the terminal and potted it. Engine in and running, and I still have code 34. I tried the resistor trick and still no love. Will an out of spec resistance throw the code as well? I have read that the sensor normally has ~6M Ohm resistance ad I am wondering how I am throwing the code. I am going to see if I can borrow a buddy's o-scope tonight and look at the signal. I am also going to try putting the resistor in the engine harness side without the sensor connected to remove that variable.
Any other ideas? (I did read the FAQ)
-Dan
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
"You're the Skrillex of Z32s." BradX (UF)
