TwinTurbo.NET: Nissan 300ZX forum - Yes, timing and tps are within spec...
Subject Yes, timing and tps are within spec...
Posted by JonnyZ(SoCal) on March 09, 2013 at 6:34 AM
  This message has been viewed 342 times.
In Reply To the ecu temp sender unit is often an issue... I assume posted by Medallion Man on March 09, 2013 at 03:57 AM
Message and after testing the coolant temp sensor again it is now within spec after being brought up to 190+ a few times.
Hopefully I can pinpoint this issue, since it only happens when it's at operating temp I think it may be a sensor, but the only things that aren't brand new are the tps, maf, injectors, cas, coil packs, ptu (replaced with new style) and coolant temp sensor. All of those have tested good so far and only have about 80k on them.
