TwinTurbo.NET: Nissan 300ZX forum - the ecu temp sender unit is often an issue... I assume
Medallion Man
on March 09, 2013 at 3:57 AM
I think it may be my coolant temp sensor!
posted by JonnyZ(SoCal)
on March 08, 2013 at 08:06 PM
You also checked the TPS voltage and timing (with a light).
Weak to no spark when car is hot!
JonnyZ(SoCal)
13:56:46 03/08/13
JonnyZ(SoCal)
20:06:44 03/08/13
the ecu temp sender unit is often an issue... I assume -
Medallion Man
03:57:48 03/09/13
Yes, timing and tps are within spec...
JonnyZ(SoCal)
06:34:02 03/09/13
Its not going to be a Coolant sensor if you are losing spark
Joe@ZSpeedperformance
11:09:48 03/09/13
They are snug and no corrosion or anything!
JonnyZ(SoCal)
15:06:35 03/09/13
recheck PTU...
puchy
14:12:23 03/10/13
Re: Weak to no spark when car is hot!
itlnstln13
23:56:16 03/10/13
itlnstln13
23:59:51 03/10/13
