TwinTurbo.NET: Nissan 300ZX forum - Valves are removed from my heads. A few of the valves are
Subject Valves are removed from my heads. A few of the valves are
Posted by Lone Z'er(CO) on March 06, 2013 at 10:38 PM
  This message has been viewed 258 times.
Message definitely bent. Some others might be. Others look perfectly fine. So how can you tell which ones are bent?
Since I'm trying to make sure the car runs before I dump a lot of money into it, does it make any sense only to replace the bent ones and not the others?
Also, when I get the heads cleaned, will I have to take anything else off the heads? The valve guides? valve stem seals?
