TwinTurbo.NET: Nissan 300ZX forum - Timing is correct. I think I counted the teeth 30 times. I
z32z
on March 05, 2013 at 9:19 PM
check your timing
posted by Zvil (FL)
on March 05, 2013 at 09:00 PM
will try the VTC solenoinds. I had a bent valve on changed my 1990 heads out for a set of 1995 heads
At 3500 to 4800 rpms my Z jerks and stumbles very bad
z32z
19:12:03 03/05/13
Mass Air Flow Sensor? Oxygen Sensor? Coil Packs?
Summeronthechain (MN)
20:36:31 03/05/13
I have a Z1 tuned ECU. Its it possible for one to lose its
z32z
20:50:10 03/05/13
No, not really possible. Moreso if you have the wrong tune
07:24:28 03/06/13
check your timing
Zvil (FL)
21:00:53 03/05/13
Timing is correct. I think I counted the teeth 30 times. I -
z32z
21:19:50 03/05/13
tps? (n/m)
inf
22:37:25 03/05/13
Began to stumble after you swapped heads? (n/m)
Gordo 93TT Daytona
10:14:30 03/06/13
Yes. My timing belt jumped and bent a valve. I sent a extra
z32z
10:56:17 03/06/13
Sounds like a bad maf sensor (n/m)
ForceFedTT (SoCal)
03:34:37 03/10/13
