TwinTurbo.NET: Nissan 300ZX forum - I have a Z1 tuned ECU. Its it possible for one to lose its
z32z
on March 05, 2013 at 8:50 PM
Mass Air Flow Sensor? Oxygen Sensor? Coil Packs?
posted by Summeronthechain (MN)
on March 05, 2013 at 08:36 PM
tune. I never heard of anyone on this site talk about that before. Also the wire harness is fairly new. I have every delete done on the motor and I cut all the extra connectors off the harness. Would that be issue ?
At 3500 to 4800 rpms my Z jerks and stumbles very bad
z32z
19:12:03 03/05/13
20:36:31 03/05/13
I have a Z1 tuned ECU. Its it possible for one to lose its -
z32z
20:50:10 03/05/13
No, not really possible. Moreso if you have the wrong tune
07:24:28 03/06/13
check your timing
Zvil (FL)
21:00:53 03/05/13
Timing is correct. I think I counted the teeth 30 times. I
z32z
21:19:50 03/05/13
tps? (n/m)
inf
22:37:25 03/05/13
Began to stumble after you swapped heads? (n/m)
Gordo 93TT Daytona
10:14:30 03/06/13
Yes. My timing belt jumped and bent a valve. I sent a extra
z32z
10:56:17 03/06/13
Sounds like a bad maf sensor (n/m)
ForceFedTT (SoCal)
03:34:37 03/10/13
