TwinTurbo.NET: Nissan 300ZX forum - ?The removal of the slave will not drain the tranny fluid>>
Subject ?The removal of the slave will not drain the tranny fluid>>
Posted by ZUL8TR on March 05, 2013 at 12:04 PM
  This message has been viewed 414 times.
In Reply To Change the clutch slave cylinder and also change the posted by MikeD (Philly) on March 04, 2013 at 11:52 AM
Message If you want to change the tranny fluid that is a seperate job. Make sure you use the correct gear oil. No GL5 is to be used in the manual tranny. There are fluids out there that are GL4 Amsoil makes a GL4 manual tranny fluid, Redline MT90 is another, and after trying several Royal Purple 75w 90 max Gear is the one I use and is the only one that has a GL4, GL5 rating that works in these Z trannies because of the compatable chemistry with the synchronizers and green metals.
Do not use Mobil 1 it is purly a GL5 gear oil and not designed for trannies using GL4.
ZUL8TR in Orlando,FL
