TwinTurbo.NET: Nissan 300ZX forum - Re: sounds like a blown head gasket
Subject Re: sounds like a blown head gasket
Posted by wh0sjeff on March 04, 2013 at 8:19 PM
  This message has been viewed 246 times.
In Reply To sounds like a blown head gasket posted by Zvil (FL) on March 04, 2013 at 06:25 PM
Message answer me something, if i were to disconnect the downpipes from the test pipes and let the test pipes hang then started the car( did them one at a time) and there was no smoke coming out. both sides were fine even when i reved the motor, and thats when i would get more smoke. i followed all the steps in the manual, hell its been my only friend thru this. head bolts arent new, i put them on in july when i got my tt heads, maybe i should get a set, but i didnt find anywhere in the manuel to replace them everytime youtake them out. block is good, heds too. the car hasnt even left the driveway or seen positive pressure. i dont wanna screw anything up so until i fix this it aint moving. im fixin to go do a compression test and check the coolant. by the way oil was fine, just dark and consistant.
