TwinTurbo.NET: Nissan 300ZX forum - need some advice, please read
Subject need some advice, please read
Posted by wh0sjeff on March 04, 2013 at 3:33 PM
  This message has been viewed 290 times.
Message okay, i just converted my car to tt and in doing so used my block, just did thre nescessary steps to my block to convert it, bought some used stock turbos and rebuilt them, lower compression forged pistons, etc. i did my homework before im started so im pretty sure i didnt forget anything. before my motor ran fine, didnt leak anything, overheat, nothing was out of spec but i had the heads resurfaced anyways, they took off .007of an inch. not much at all, anyways so i get everything together and started it up and it is smoking lightly at idle, more as i rev the motor and im losing coolant, well, water now. changed oil and it was fine, just black due to the assembly lube.trying not to have to pull the motor if its somethingi can fix with the motor in, any ideas?
