TwinTurbo.NET: Nissan 300ZX forum - Change the clutch slave cylinder and also change the
Subject Change the clutch slave cylinder and also change the
Posted by MikeD (Philly) on March 04, 2013 at 11:52 AM
  This message has been viewed 1686 times.
In Reply To Re: I'd be curious to know what he saw in 10 sec that made him posted by hnunez008 on February 28, 2013 at 03:18 PM
Message connecting clutch line too. Most likely your problem is in the clutch line and the line is leaking fluid when you depress the clutch in to change gears. Get a new Nissan slave cylinder and a aftermarket SS braided clutch line along with some new DOT 4 brake fluid.
Also when you change the slave cylinder you will end up draining the trans manual gear fluid as the slave cylinder bolts directly to the transmission. Good time to replace that fluid too.
