TwinTurbo.NET: Nissan 300ZX forum - Re: Check the eng cont fuse under the hood.
Subject Re: Check the eng cont fuse under the hood.
Posted by tytyisfly27 on February 26, 2013 at 6:57 PM
  This message has been viewed 199 times.
In Reply To Check the eng cont fuse under the hood. posted by ShakaShaun(Denver) on February 26, 2013 at 06:34 PM
Message Fuse is good. All injectors are firing when the CAS is rotated manually, I will double check for voltage though.
You can't do a power balance test if the engine isn't running, correct?
