TwinTurbo.NET: Nissan 300ZX forum - Re: Upper intake manifold gasket saturated with fuel
Subject Re: Upper intake manifold gasket saturated with fuel
Posted by backinblack626 on February 25, 2013 at 8:49 AM
  This message has been viewed 178 times.
In Reply To Upper intake manifold gasket saturated with fuel posted by white22sky on February 24, 2013 at 03:32 PM
Message Fuel rail to plenum seals, fuel damper or fpr. See if there is fuel in the plenum? Does the upper stink of fuel? Also check the rubber fuel hose that crosses over the fuel rails. If that hose isn't culprit one of the other items I listed is. If you do fuel rail to plenum seals do your injectors o rings too for peace of mind.
