TwinTurbo.NET: Nissan 300ZX forum - #11 - crank angle sensor circuit
Subject #11 - crank angle sensor circuit
Posted by Medallion Man on February 24, 2013 at 3:15 AM
  This message has been viewed 203 times.
In Reply To Re: Re: Re: car not starting posted by reaperz1 on February 23, 2013 at 06:01 PM
Message looks like you have adjusted the TPS too much for the car to be able to work with the CAS setting.
BUT first check CAS & PTU connectors.
so both TPS and timing are out.
maybe put it back to .39 and check the timing (should be 15 tdc) see tech section.
when was the last timing belt done?
if there is no adjustment left on the CAS it could be the timing belt is on wrong or slipped a cog.
see MA section in Service Manual for cog count. ([ http://z32.wikispaces.com/Factory+Service+Manual ])
