TwinTurbo.NET: Nissan 300ZX forum - Lifter Replacement
Subject Lifter Replacement
Posted by zman03 on February 22, 2013 at 12:35 AM
  This message has been viewed 228 times.
In Reply To I just replaced all of my lifters using the stock original posted by SammybTT(TN) on February 19, 2013 at 12:49 PM
Message To Sammyb's post I am curious what he did during the lifter re-furnbishment that destroyed the lifters if I understand correctly. I have my engine top apart now and had a bad lifter tic prior to disassembly. The engine is badly contaminated with oil coke so I was thinking I might disassemble the front and then remove the cams and clean the lifters following the procedure Ash wrote up. Of course I will mic everything to the factory specs in the process but I want to reuse as many parts as possible. So, what went wrong with the lifter refurbishment if you don't mind me asking?
