TwinTurbo.NET: Nissan 300ZX forum - From your questions, it seems you're not sure what to do.
Subject From your questions, it seems you're not sure what to do.
Posted by zellamay on February 18, 2013 at 12:15 AM
  This message has been viewed 245 times.
In Reply To Can you replace all the lifters and use the stock cam posted by 1995z32tt on February 17, 2013 at 06:43 PM
Message What makes you think the cam is worn out, or "worn into these lifters"? If you've got it apart, the thing to do is measure everything. .... Your question doesn't make sense to me. Why wouldn't you be able to "replace all the lifters and use the stock cam"? But then the question is: why would you do that? If your lifters are ticking it could be an oiling problem, like a dented oil pan, or an old, low oil pressure engine.
