TwinTurbo.NET: Nissan 300ZX forum - Re: Adjusting out INTERNAL slop in the steering rack >>>
Subject Re: Adjusting out INTERNAL slop in the steering rack >>>
Posted by backinblack626 on February 16, 2013 at 7:23 PM
  This message has been viewed 417 times.
In Reply To Adjusting out INTERNAL slop in the steering rack >>> posted by my91z on February 15, 2013 at 04:23 PM
Message You sure the play isnt in the inner tie rods? Is it exactly the same on both sides? Is the steering wheel unlocked when you do this? To make sure have someone sit in the car and hold the steering wheel tight and then shake the wheel back and forth. If you put your hand on the tie rod you should be able to tell if its clicking right inside the rack. If so its almost definitely the inner tie rods. Wouldnt be first I have replaced. They probably used cheaper parts when rebuilding yours.
