TwinTurbo.NET: Nissan 300ZX forum - Re: Folks often de-pin those ECU connectors when installing
Subject Re: Folks often de-pin those ECU connectors when installing
Posted by someotherguy on February 16, 2013 at 7:22 PM
  This message has been viewed 323 times.
In Reply To Folks often de-pin those ECU connectors when installing posted by jzack on February 16, 2013 at 07:14 PM
Message So how do you de-pin the connector? The connector pin in question looks the same as the rest. The problem seems to be a break in the connection between the pin and the wire it's connected to. If I could figure out how to get the pin out of the connector without destroying anything I could re-solder the connection and re-install the pin
