TwinTurbo.NET: Nissan 300ZX forum - Folks often de-pin those ECU connectors when installing
Subject Folks often de-pin those ECU connectors when installing
Posted by jzack on February 16, 2013 at 7:14 PM
  This message has been viewed 505 times.
In Reply To Repair ECU connector posted by someotherguy on February 16, 2013 at 05:28 PM
Message a new wiring harness (making it easier to get the wiring from the engine bay into the cabin). So seems like a reasonable way to solve your issue?
Kind of strange you are having a wire continuity issue that close to the ECU connector block? Maybe there's just an issue with that connector pin (that could be repaired?)...
PS - Another way to tackle this issue, open up the ECU case and a solder a wire to the ECU board, run it thru the case and terminate with some kind of male/female quick connect then make your connection at the harness. Not pretty but given the ECU's are rarely disconnected, does it really matter?
