TwinTurbo.NET: Nissan 300ZX forum - O2 sensor help. Techtom reading 2.55 volts...
Subject O2 sensor help. Techtom reading 2.55 volts...
Posted by Bucky Z on February 16, 2013 at 3:46 PM
  This message has been viewed 228 times.
Message And the car is running very rich. Even with the garage door open I nearly choke to death on the fumes. It's the passenger side O2 sensor that's reading 2.55 volts on the Techtom. I even just replaced that sensor with a new one and am still getting the same reading.I get an all clear code 55 from the ECU. I don't see how the harness wiring could be bad as it is still basically new with barely 500 miles on it. I did plenty of searching and found posts from people with the same problem, but no one ever posted a solution!! Any suggestions are much appreciated.
Later,
B.U.C.K.Y.: Biomechanical Unit Calibrated for
Killing and
Yardwork
