TwinTurbo.NET: Nissan 300ZX forum - My reasoning would lead me to believe
Subject My reasoning would lead me to believe
Posted by Zvil (FL) on February 13, 2013 at 12:12 PM
  This message has been viewed 158 times.
In Reply To 28PSI is in the area I was thinking. posted by white22sky on February 13, 2013 at 11:02 AM
Message at the same boost a higher compression motor would make more power at the same boost, but that is because your end cylinder pressure would be higher at the cost of requiring higher octane/less timing.
with the same end cylinder pressure, different compression ratios: the lower compression motor will make more power due to efficiency.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to in-politely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
