TwinTurbo.NET: Nissan 300ZX forum - move the cams
Subject move the cams
Posted by aliaZ on February 13, 2013 at 10:19 AM
  This message has been viewed 188 times.
In Reply To Setting Timing on Newly Built Block posted by TwinTurboZ19 on February 13, 2013 at 01:10 AM
Message the cams naturally want to rotate to the position with the least valve spring tension. When all the cams are in this position all of the valves are closed. You can rotate the crank in this configuration without worry of pistons hitting the valves
Then move the cams one at a time to the proper position, rotating by hand. If you feel a valve contacting a piston, stop and rotate the crank maybe 20 degrees, and then try again. Return the crank to TDC after each cam movement.
