TwinTurbo.NET: Nissan 300ZX forum - Instead of grinding the rivets and removing the guage -
Subject Instead of grinding the rivets and removing the guage -
Posted by jzack on February 12, 2013 at 11:22 PM
  This message has been viewed 709 times.
In Reply To More gauge cluster repair info. posted by DVDBURN (MD) on February 12, 2013 at 08:53 PM
Message any reason not to just run a jumper from the board connection point and solder it to a rivet head or heads (since it appears to be a ground/shielding connection). Maybe then just re-flow the solder to the gauge connector pins?
I'd probably give that a try -- if issues, then do the more rigorous fix?
