TwinTurbo.NET: Nissan 300ZX forum - Exhaust side makes a big difference
Subject Exhaust side makes a big difference
Posted by nzryan on February 11, 2013 at 3:12 PM
  This message has been viewed 278 times.
In Reply To Larger turbos lower under hood/ engine temps? posted by Jkova300z on February 11, 2013 at 10:24 AM
Message What a lot of people seem to forget when comparing little turbos to big turbos is the exhaust side, a bigger turbo will generally have a bigger exhaust wheel/housing, this means that the bigger turbos will be less restrictive on the exhaust - not ~blocking~ the exhaust as much.
So the bigger turbo at 16 Psi will make more HP because it allows more air to move ~through~ the motor than the smaller turbo at 16 psi would because the exhaust is not as ~blocked~ with the bigger turbo than it would be with the smaller turbo.
