TwinTurbo.NET: Nissan 300ZX forum - Larger turbos lower under hood/ engine temps?
Subject Larger turbos lower under hood/ engine temps?
Posted by Jkova300z on February 11, 2013 at 10:24 AM
  This message has been viewed 225 times.
Message Is this thought true? My rational was: if you run larger turbos vs stock, the stock turbos at say 16 psi will be pushing hotter air and working less efficient, where as BIGGER turbos at same psi or even lower, will push a larger volume of air but not working as hard. Effectively making more hp but not with as much heat/ effort?
