TwinTurbo.NET: Nissan 300ZX forum - when you say oil is leaking out...
Subject when you say oil is leaking out...
Posted by Medallion Man on February 09, 2013 at 5:45 AM
  This message has been viewed 209 times.
In Reply To possible seized turbo? posted by omid on February 09, 2013 at 04:08 AM
Message Have you checked the dip stick?
It cold have blown out and oil could be coming from there…
As for the running issue.. can you do a boost/vac leak test?
Also by the sounds of it you need to do a full set of checks on the car.
Timing (with a timing light), TPS voltage, coil pack T injector resistance, check plugs,
Throttle body alignment, Air filter check and clean all electrical connectors.
If you look in the tech section you will see guides for lost of things running related.
Oh and be prepared to get your hands dirty …
Best of luck.
