TwinTurbo.NET: Nissan 300ZX forum - white smoke/coolant smell/back of engine
Subject white smoke/coolant smell/back of engine
Posted by JBRAVO373 on February 06, 2013 at 10:12 PM
  This message has been viewed 364 times.
Message 92 NA
the car was in the garage for about 2 weeks while i replaced the injectors and the wiring harness .
the started right up and idled perfect , went around the block and the power was there . turned it off in the driveway and it started smoking at the rear of engine. no leak on the ground tho
as i installed the ecu harness i think i punctured the heater core? all the Freon leaked out . it was yellow and sticky. would this be the cause or head gasket ?
