TwinTurbo.NET: Nissan 300ZX forum - Yes, I believe there should be
Subject Yes, I believe there should be
Posted by Summeronthechain (MN) on February 03, 2013 at 11:19 AM
  This message has been viewed 193 times.
In Reply To I don't think boost should pass through to the hose posted by njz on February 03, 2013 at 08:00 AM
Message When doing a boost leak test as described by the OP, positive pressure would enter the crank case. When it enters the crank case it will fill up the four PCR lines (2 on the front under the throttle bodies and 2 on the rear connected to the PCV valves)
