TwinTurbo.NET: Nissan 300ZX forum - Alternator water pump belt (n/m)
njz
on February 01, 2013 at 10:14 PM
Get this belt Gatorback # 4040382 (n/m)
posted by njz
on February 01, 2013 at 10:13 PM
Startup belt squeal....
HK'S Z
13:45:56 01/31/13
Need to be tightened most likely. (n/m)
Evan_Wright (Ca)
14:28:06 01/31/13
Thanks Evan. Sadly they are as tight as can be...
HK'S Z
14:59:16 01/31/13
Stock belts? Or do you have shorter ones due to the UDPulley (n/m)
ZinnZ32
15:12:25 01/31/13
No, I have the shorter belts for the UD pulleys :( (n/m)
HK'S Z
16:21:45 01/31/13
Is there such a thing as the belt being too tight?
Stokens (StoMoZTT)
15:39:54 01/31/13
Thanks. I will give that a try. (n/m)
HK'S Z
16:21:15 01/31/13
Yes, bearings can fail from too much tension (n/m)
RoidRage76
18:15:27 01/31/13
+1 I've seen that happen first hand
Zvil (FL)
21:14:12 01/31/13
Don't do this with the engine on ;-) (n/m)
Shiers69
10:30:29 02/01/13
lol (n/m)
Zvil (FL)
21:34:15 02/01/13
Hahaha. Thanks Zvil. I ll try to remember to turn it off. (n/m)
HK'S Z
19:01:18 02/03/13
njz
22:13:15 02/01/13
Alternator water pump belt (n/m) -
njz
22:14:44 02/01/13
Thank you, I will give that one a try. (n/m)
HK'S Z
18:59:45 02/03/13
Re: Get this belt Gatorback # 4040382
Hydrus
18:04:14 02/04/13
njz - Thank you!!! No more squeal. (n/m)
HK'S Z
10:03:48 02/06/13
Sounds like its too tight . Try to loosen it some . (n/m)
Xteam300TT (South Tx )
19:31:55 01/31/13
^^ 2nd Loosen them
SammybTT(TN)
23:03:01 02/02/13
So I loosened them a bit...made it a lot worse.
HK'S Z
12:50:20 02/04/13
The gatorback belt is for the ps to ud pulley correct? (n/m)
Hydrus
18:02:10 02/04/13
HK'S Z
10:38:00 02/05/13
Would you happen to know the number for the ps belt? I have
Hydrus
16:55:31 02/05/13
the pulley itself can wear out
aliaZ
18:43:51 02/01/13
