TwinTurbo.NET: Nissan 300ZX forum - I plan to run the tt clutch booster
Subject I plan to run the tt clutch booster
Posted by Jayru on January 31, 2013 at 10:45 AM
  This message has been viewed 176 times.
In Reply To The booster is under the dash. Engine does not need to posted by white22sky on January 31, 2013 at 08:09 AM
Message minus the vacuum tanks. I had a hard time locating a good condition NA pedal, and I have the tt on hand. I'm going to run the check valve and a vacuum hose directly to the booster and see what happens. Thinking it will be the best of both worlds (assist when in traffic with sufficient vacuum, and just stiffer when under boost/no vacuum, etc.) - The wiring is still a mystery though. Hoping to use the factory wiring out of a 5 speed tt and "plug n play" into the auto car.
93 2+2 Twin Turbo Track Build - jsworks.org for more info!
