TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: engine idles after ingition turns off (Dieseling)
Subject Re: Re: Re: engine idles after ingition turns off (Dieseling)
Posted by Jeankido on January 30, 2013 at 11:17 AM
  This message has been viewed 176 times.
In Reply To Re: Re: engine idles after ingition turns off (Dieseling) posted by Jeankido on January 30, 2013 at 07:19 AM
Message when performing the Carbon canister delete i sealed the fuel tank line. I think all the pressure cause this dieseling fealing. So i solved the engine idling after ignition is switched off.
but still have this stubborn cylinder with compression at 190psi,fuel, comfirmed spark at the coil and the plug when pulled out and tested visually/audibly. i am going to swap my ecu with one that is known good and see what happens.
