TwinTurbo.NET: Nissan 300ZX forum - Re: Hesitation problem
Subject Re: Hesitation problem
Posted by Zeto32 on January 30, 2013 at 2:42 AM
  This message has been viewed 156 times.
In Reply To Hesitation problem posted by MyninjaZ32 on January 29, 2013 at 04:57 PM
Message Only in 3rd gear? Is it an Auto or Manual?
I used to have bad hesitation as well. I found out that the problem was the Spark Plugs, Fuel Filter, Corrosion on the injector connectors, TB butterfly stop screw, and CAS. Once I had adjusted all of those, it quit hesitating.
Check the basic stuff, for instance. Do you have the correct NGK plugs? Is your ignition timing correct? Is your TPS correct? Have you replaced the fuel filter at all? etc...
This can help you on what to do and look for.
[ http://www.twinturbo.net/nissan/300zx/FAQ/FAQpages/hesitate2.html ]
Good Luck
