TwinTurbo.NET: Nissan 300ZX forum - Oil coked engine
Subject Oil coked engine
Posted by zman03 on January 30, 2013 at 1:37 AM
  This message has been viewed 165 times.
In Reply To Stop leak = no good. Yes, you will need to clean posted by Tanley on January 29, 2013 at 05:48 AM
Message Thanks very much for your responses, I really appreciate it!
I've been using Mobil 1 oil mixed with the Lucas crap. Removing the lifters involves the timing belt and I don't want to try to do to many things at one time so I am going get it back running first then do the t-belt.
The T1 sounds like a great idea but I also want to do what I can while the valve covers are off so Im going to clean the top of the engine with carb cleaner or pb blaster and vacuum up what I can and then flush through the pan with some cheap oil.
I'll change the oil every few hundred miles for the first half dozen times when I get it back running and hope for the best then start on a rebuild. I have a salvage JDM NA engine I bought awhile back I could build up but need to figure out how to build as a TT engine.
Here are the pictures again if they work this time?
[img border=0 Src="http://s1352.beta.photobucket.com/user/Socalz/media/image_zps8ff3eb6c.jpg.html?sort=3&o=1">
[img border=0 Src="http://s1352.beta.photobucket.com/user/Socalz/media/image_zps3aaec492.jpg.html?sort=3&o=2">
[img border=0 Src="http://s1352.beta.photobucket.com/user/Socalz/media/image_zps469c9a06.jpg.html?sort=3&o=0">
