TwinTurbo.NET: Nissan 300ZX forum - Re: Re: HELP! Auto Climate Control Has NO POWER!!!
Subject Re: Re: HELP! Auto Climate Control Has NO POWER!!!
Posted by backinblack626 on January 25, 2013 at 7:59 PM
  This message has been viewed 572 times.
In Reply To Re: HELP! Auto Climate Control Has NO POWER!!! posted by robsheer on January 24, 2013 at 08:19 PM
Message Check to see if you have power the fuse first. If there is power there and the fuse is not blown then the problem lies after that. My turn signals and air control are on the same circuit and every time i use my blinkers I blow the fuse that sends power to both. Probably bad bulb sockets but ill let you know when I finish replacing ds turbo. I believe the auto amp is deep in the dash if I remember correctly.
