TwinTurbo.NET: Nissan 300ZX forum - Will the engine turn over using the crank pulley nut?
Subject Will the engine turn over using the crank pulley nut?
Posted by Gordo 93TT Daytona on January 23, 2013 at 6:01 PM
  This message has been viewed 249 times.
In Reply To Possible engine failure....any thoughts...? posted by jmt-z on January 22, 2013 at 11:41 AM
Message If it moves back and forth, but doesn't rotate very far; then it is not seized, but you probably have an obstruction, like a valve into a piston.
_________________________________________________
