TwinTurbo.NET: Nissan 300ZX forum - Re: Replace them, there is no reason to continue using them.
Subject Re: Replace them, there is no reason to continue using them.
Posted by DTuckAndRoLL on January 23, 2013 at 2:51 PM
  This message has been viewed 244 times.
In Reply To Replace them, there is no reason to continue using them. (n/m) posted by TriniTT on January 23, 2013 at 02:45 PM
Message It does not run terrible. Slightly slugish from a dead stop but I always assumed it was trying to flood itself out. The idle isn't terrible. It is higher slightly than I understand it should be. And the only reason I would say chip it is because I can buy a chip for 100 bucks and use my soldering skill on a spare ecu I have to do it myself as opposed to spending say 500 on a set of injectors then the conversion kit on top. If it will run fine with a chip for a few months then grea. Like i said I do plan on swapping it out.
