TwinTurbo.NET: Nissan 300ZX forum - Grease the clutch fork pivot ball. This can be reached>>
Subject Grease the clutch fork pivot ball. This can be reached>>
Posted by ZUL8TR on January 23, 2013 at 8:18 AM
  This message has been viewed 391 times.
In Reply To Squeaky / Sticky Clutch posted by 300zxNA2TT on January 22, 2013 at 10:48 AM
Message by dropping the slave cylinder without disconnecting the hydraulic hose and pulling back the dust boot on the fork then with a grease gun with a needle grease tip get the grease on the pivot ball.
happened to my clutch and that solved the squeek.
As far as smooth operation try a bleed job
If all fails the problem is probably internal to the clutch assembly.
ZUL8TR in Orlando,FL
