TwinTurbo.NET: Nissan 300ZX forum - check ecu for codes. might be a loose connection. look for
Krazyd27(Houston)
on January 22, 2013 at 12:31 PM
Possible engine failure....any thoughts...?
posted by jmt-z
on January 22, 2013 at 11:41 AM
Corrosion around cas, ptu, coolant temp sensors. If you do get it to start perform a power balance test by renoving spark from each cylinder via unplugging coil pack to make sure each cylinder is firing. Best of luck
jmt-z
11:41:53 01/22/13
check ecu for codes. might be a loose connection. look for -
Krazyd27(Houston)
12:31:33 01/22/13
Re: Possible engine failure....any thoughts...?
craigz96tt (SC)
14:11:03 01/22/13
2nd, that sounds precisely like a timing belt issue. (n/m)
TriniTT
15:38:29 01/22/13
and we have a winner..... I was seriously leaning towards
jmt-z
16:07:11 01/22/13
I'd say your motor is probably toast based on your reaction
TriniTT
16:16:06 01/22/13
Are you running without T-belt covers?
Zvil (FL)
17:38:45 01/22/13
Left the timing belt covers off from the last time i was
jmt-z
18:07:28 01/22/13
Sorry to hear
SeanK (StL)
11:51:21 01/23/13
Yeah man I would have taken you up with it but i already
jmt-z
17:28:59 01/23/13
2 thoughts....
Zvil (FL)
17:32:55 01/22/13
Just my 2 cents
boostlv
12:04:04 01/23/13
check your starter
boostlv
12:08:14 01/23/13
Will the engine turn over using the crank pulley nut?
Gordo 93TT Daytona
18:01:05 01/23/13
