TwinTurbo.NET: Nissan 300ZX forum - One Dead Injector?
Subject One Dead Injector?
Posted by Cjw3 on January 19, 2013 at 12:55 PM
  This message has been viewed 179 times.
In Reply To Cold start issue posted by BigZness on January 19, 2013 at 12:31 PM
Message Dead Injectors do not run.. I doubt your car is running on 5 Cylinders, and you are only complaining about Hard Starting.. Need to check that further.. that diagnosis sounds suspect to me..
Cold Start issues CAN be from a Bad ECU water Temp Sender.. or a dirty MAF air temp sender..
$500 is a lot of money for a Cold Start Issue.. I'd use it for other maint issues.. Likely I'd find another shop to work with. not that this Guy is that bad, but his ability to explain the problem in your terms is Lacking.. So I'd look for a Doctor with a better bed side manor..
Cj
