TwinTurbo.NET: Nissan 300ZX forum - That does not need to be removed or capped.
Subject That does not need to be removed or capped.
Posted by TriniTT on January 18, 2013 at 3:51 PM
  This message has been viewed 228 times.
In Reply To Re: Which pipe? posted by Black_Z32 on January 18, 2013 at 12:39 PM
Message If you look at this image in the top right corner is the line you're seeing in the 2nd image. If you see where that line comes out in the 2nd pic (directly to the right of the hose marked "11"), you can follow it down to the left below the pcv line and right to the EGR valve. With the EGR gone, it's just open on both ends now. You could remove it if you wanted, but it isn't necessary.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
