TwinTurbo.NET: Nissan 300ZX forum - yeah.... to my knowledge there exists 700ftlb NA clutches
Subject yeah.... to my knowledge there exists 700ftlb NA clutches
Posted by Zvil (FL) on January 17, 2013 at 11:35 AM
  This message has been viewed 169 times.
In Reply To Re: About ebay turbos posted by wh0sjeff on January 17, 2013 at 01:37 AM
Message the main difference/benefit is clutch surface area, it's better to do more surface area and less pressure. Everytime you press the clutch the weight from the pressure plate is also pushing the crank forward which wears your lateral crank bearing out and in some cases it will wear out your bearing to the point of causing crank walk...... To help alleviate some of that stress I disabled the clutch sensor for starting up, so now when the motor is cold and all the oil has settled to the pan I just put the tranny in nuetral and start the motor without clutching :)
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to in-politely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
