TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Bore clearance question?
Subject Re: Re: Re: Bore clearance question?
Posted by Tech@EPR on January 16, 2013 at 5:48 AM
  This message has been viewed 155 times.
In Reply To Re: Re: Bore clearance question? posted by wickdGSXR on January 15, 2013 at 12:30 AM
Message 3.2L with just piston displacement and no stroke? The stock block doesn't have enough material in the bores to adopt a piston much bigger than 89mm. Some are lucky to get away with 90mm but you are getting REALLY risky in doing so. If you wanted to run that much bore I'd of suggested to go with a hardened sleeve and then bore out to desired diameter.
Ep Racing | Create Your Badge
