TwinTurbo.NET: Nissan 300ZX forum - I ran my ground cable from the battery to the chassis
Subject I ran my ground cable from the battery to the chassis
Posted by Zvil (FL) on January 15, 2013 at 8:54 PM
  This message has been viewed 481 times.
In Reply To Battery Relocation question posted by ConverTTZ on January 15, 2013 at 08:10 PM
Message then the firewall to the stock ground point on the transmission, ABSOLUTELY no starting issues whatsoever. You don't need to run an additional wire for ground as long as you have a healthy contact point for the ground cable to attach to on both ends. I highly recommend insulating/looming the positive cable well and run it through the center of the vehicle, avoid any spots under carpet that can be stepped on or pushed against or any sort of surface where you can place items on top of. I also purchased/recommend a quality high amperage circuit breaker which is a good safety measure when you consider you're running a constantly live 15ft battery cable through your car..... THAT is a potential fire waiting to happen :)
Get yourself a quality pass-through bolt that is insulated well.
I put mine straight down from the Radio.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to in-politely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
