TwinTurbo.NET: Nissan 300ZX forum - TT Clutch Pedal/Booster Question
Subject TT Clutch Pedal/Booster Question
Posted by Jayru on January 14, 2013 at 6:50 PM
  This message has been viewed 233 times.
Message Does anyone know what happens if you use a TT clutch pedal assembly without all the air tanks hooked up? Just capping the vac port on the booster. Does It basically just give you a stiff pedal like an NA setup would? Or does it not allow the pedal/slave to work properly? TIA!
93 2+2 Twin Turbo Track Build - jsworks.org for more info!
