TwinTurbo.NET: Nissan 300ZX forum - it is under a slight vacuum
aliaZ
on January 13, 2013 at 3:28 PM
but isnt that air always in vacuum? not to mention metered? (n/m)
posted by LJZTT
on January 13, 2013 at 10:33 AM
there is a pressure differential between the air filter and the throttle body. And you are correct, the air is metered
Need some help fellas... Creamy oil
Project_Broke
09:42:06 01/10/13
What does your coolant system look like?
TriniTT
11:49:09 01/10/13
Re: What does your coolant system look like?
Project_Broke
12:18:17 01/10/13
Compression test.
Red Hawk (CO)
14:39:31 01/10/13
BAD to bypass the PCV System
Cjw3
13:42:49 01/10/13
^this (n/m)
Zvil (FL)
13:48:52 01/10/13
I dont think PCV is causing this.
Red Hawk (CO)
14:31:46 01/10/13
I think you're wrong
aliaZ
16:15:07 01/10/13
higher pressure will always move to low pressure
Red Hawk (CO)
01:09:10 01/11/13
yes, but you're still wrong
aliaZ
11:59:25 01/11/13
Tell me where this "fresh air" comes from
Red Hawk (CO)
12:30:25 01/11/13
It's the 5/8 Inch lines that hook to the Intake Tubes
Cjw3
15:05:04 01/11/13
fresh air comes from the tubes on the front of the intake
aliaZ
16:53:58 01/11/13
10:33:55 01/13/13
it is under a slight vacuum -
aliaZ
15:28:23 01/13/13
Hmm.. Sounds good.. but..
Cjw3
16:21:48 01/10/13
I ended up hooking up one of the PCV valves back up
Project_Broke
18:14:43 01/10/13
I run a catch can and no pcv valves with E85 my can catches
scottmt21
19:57:56 01/11/13
