TwinTurbo.NET: Nissan 300ZX forum - Re: What are symptoms of a failing/failed O2 sensor?
Subject Re: What are symptoms of a failing/failed O2 sensor?
Posted by craigz96tt (SC) on January 13, 2013 at 8:14 AM
  This message has been viewed 258 times.
In Reply To What are symptoms of a failing/failed O2 sensor? posted by LJZTT on January 13, 2013 at 06:49 AM
Message The voltage will be off on the Datascan and won't cycle the same as the other sensor also the "feel" will be at light throttle it will seem like the car is not getting enough gas when you start to accelerate. Biggest thing is you'll get codes if a sensor is bad. Codes for Datascan are 91 rt side and 101 for left side. Hope this helps you
