TwinTurbo.NET: Nissan 300ZX forum - Boost Controller not controlling
Subject Boost Controller not controlling
Posted by rgonzales39355 on January 11, 2013 at 9:46 PM
  This message has been viewed 257 times.
Message Thanks in advance TT.net your the bestest.
Ok so my Greddy Profed B spec 2 won’t limit my boost no matter what I have it set to. It used to work but I’m not sure when it quit working. This is what happened before I noticed it not working. My clutch started slipping so when I replaced my clutch with a RPS 5 puck and lightened flywheel. While I had the tranny out I installed SZ 3 inch down pipes and 3” to 2” test pipes. As soon as I got it back on the road I couldn’t control my boost like I used too. Before the install I would keep the boost set at 12.5 PSI. I verified this with a aftermarket gauge and the setting on the controller. After the install boost would boost all the way up to 17. I tried lowering it but know matter how I adjusted it I couldn’t get the boost to come down at all. I thought maybe my issue was a boost leak. I did a boost leak test and had to replace both of the intercoolers and one of the accordion pipes. I fixed all my boost leaks except for one coming off the EGR. I don’t know if it’s the EGR itself or the rubber hose coming off of it. With the leak in the EGR I can still build about 3.5 psi off pressure on the leak tester gauge. Could this leak be what’s causing my controller to be unresponsive? I still think that I should be able to adjust the pressure a little bit with my controller. These are the settings I tried on my controller:
Set 35
Set gain 5
Gain 5%
Limiter 0
Set 35
Set gain 90
Gain 5%
Limiter 0
I tried adjusting the Set up and down to lower the amount of boost and know matter what it doesn’t respond. I tried lowering the set gain as I lowered the set and it still doesn’t respond.
If I understand correctly Set is the duty cycle, the higher the duty cycle the higher the boost. Set Gain is supposed to be set 1-2 psi lower then the target pressure. Gain is to help with boost spikes.
I also swapped out the solenoid on the controller with a new one because I thought the solenoid was bad but I still get the exact same problem.
At this point I am really frustrated and don’t know what to do next. I feel like I should get a new controller but after swapping out the solenoid I don’t know if that will fix anything. Any help will be greatly appreciated. I apologize for my post being so long.
My details:
1993 2+2 with JDM TT swap, Z1 ECU, JWT filter, SZ 3 inch down pipes 3-2 test pipes, cat back exhaust, carbon canister delete, PRVR delete, Cruise control delete, 5 puck clutch, RPS flywheel, Unorthodox under drive pulley, H.I. waterpump pulley I think that’s all.
JDM TT swap
JWT pop charger
SZ 3 inch downpipe
SZ 3-2.5" test pipe
SZ/RPS lightened flywheel
SZ/RPS 5 puck clutch
unorthodox under drive pulley
UR HI waterpump pulley
unknown brand 2.5" catback
Z1 ECU
Greddy profec B boost controler
Stillen radiator hardpipe
Mishimoto radiator
Deleted hot start solenoid
AIV solenoid delete
Cruise Control delete
interior innovation seat skins
