TwinTurbo.NET: Nissan 300ZX forum - Re: I had the exact problem with timing and hesitation
Zeto32
on January 11, 2013 at 6:07 PM
posted by Project_Broke
on January 11, 2013 at 07:55 AM
Really? When I turn mine, my idle adjusts just fine. What would be some symptoms of a bad IACV?
Need Help With Ignition Timing and TB
Zeto32
15:47:31 01/07/13
Do you know how to set the timing? Why are you messing with
craigz96tt (SC)
15:52:03 01/07/13
First things first
Red Hawk (CO)
16:09:54 01/07/13
Yep, this^.
TriniTT
17:52:12 01/07/13
Re: First things first
Zeto32
17:50:58 01/08/13
Re: Need Help With Ignition Timing and TB
Zeto32
17:40:24 01/08/13
The 0.45v setting on the TPS is not necessarily the >>
ZUL8TR
06:55:09 01/09/13
Re: The 0.45v setting on the TPS is not necessarily the >>
Zeto32
11:48:06 01/09/13
Even though new is it properly set? As noted above>>
ZUL8TR
16:50:55 01/09/13
Re: Even though new is it properly set? As noted above>>
Zeto32
21:12:54 01/09/13
Only use a digital VOM. The throttle body difference >>>
ZUL8TR
08:57:07 01/10/13
this might help...
Medallion Man
04:18:14 01/10/13
and this...
Medallion Man
04:49:01 01/10/13
Re: this might help...
Zeto32
02:18:28 01/11/13
Project_Broke
07:55:30 01/11/13
Re: I had the exact problem with timing and hesitation -
Zeto32
18:07:52 01/11/13
