TwinTurbo.NET: Nissan 300ZX forum - I'm not sure what you mean?
Summeronthechain (MN)
on January 10, 2013 at 7:54 PM
New!
posted by Zinprogress
on January 10, 2013 at 06:23 PM
Your viscous clutch fan spins? Thats normal. There should be a fair amount of resistance when the engine is off
heater problems
Zinprogress
10:01:14 01/10/13
There is a valve on the heater core that must open.
TriniTT
11:51:03 01/10/13
Re: There is a valve on the heater core that must open.
Zinprogress
12:21:02 01/10/13
Do you have any leaks? Does your gauge go to normal op temp?
TriniTT
14:51:19 01/10/13
Re: Do you have any leaks? Does your gauge go to normal op temp?
Zinprogress
15:48:01 01/10/13
My experience with a similar issue:
Zvil (FL)
13:45:19 01/10/13
Re: My experience with a similar issue:
Zinprogress
14:21:14 01/10/13
Zinprogress
15:44:01 01/10/13
Sounds like your thermostat might be stuck open. (n/m)
16:19:43 01/10/13
New!
Zinprogress
18:23:00 01/10/13
I'm not sure what you mean? -
19:54:52 01/10/13
Re: I'm not sure what you mean?
Zinprogress
20:22:36 01/10/13
Explanation
07:57:47 01/11/13
Well then thermo first?
Zinprogress
09:40:34 01/11/13
Stock thermostat works and I tried bleeding to get the...
Zinprogress
14:43:40 01/11/13
